reddog64
So the dana 60 is swapped in, with the 52's and zero rates and 7 inch shackle. Used all kert's stuff ( it rocks)
Axle is 3 inches forward from stock.
I'm lookin at the pinion angle and wondering what to do for a front driveshaft...
I can make one using square tube, or call HAD...
But something has to be done about the pinion angle. It almost looks like it is pointed straight back, meaning level...
If i run a cv up front, doesnt eth pinion need to be pointed up to the transfer case, like my rear axle is???
If i run 1410's on both ends, the angles just need to match right?
Edit -
I did some searching on "front pinion angle" and found that everyone said start at 2 degrees and go up from there...
Problem is I dont have a front shaft i'm gonna run yet...
And what about teh dana 60 pass side spring plate.. If i shim it, the two bolts will bind...
Can i shim the front up some?
If i do shim it up, teh case and pinion angles wont match... and it wont be enought to properly run a cv...
What's everyone else doing?
78 K5 350/400/205 60/70HD 52's and 56's with zero rates and
Edit -
