Front Spring Bushings
Decided i didn't care do to the FUSH upgrade.
That being said, the HD shackles/bushings include both upper and lower rear shackle bushings. Or at least the pic says so.
So, i should be good. Thanks for the comment!
Ok cool :waytogo: Just wanted to let you know. I know I eliminated a lot of play with shackles and the fush kit in my trail rig there. Getting ready to do the same with the V3500 soon.
Stock bushings have the rubber bonded to the inner and outer sleeves, so suspension movement is a "twist", while poly bushings do a "slide". That's why the rubber is basically silent and poly is known to sometimes creak.
