Front Spring Hanger
fabjunkie
Dallas Outskirts
I need a front driver spring hanger. I think they're the same as 1/2 and 3/4 ton trucks. Hell left and right is probably the same. Someone help me out here! :D
Do you need the front spring front hanger, or the rear spring front hanger?
I am guessing front spring.
Either way I got some.
want one or both sides?
$15 for one or $25 for both and shipping should be $11.50 flat rate box.
Front spring, front hanger, driver side. But like I said I think they're all the same. If they're in good shape, I'll take both sides. How are the holes? Got pics? Thanks.
Well too late now for the pics, tomorrow morning I will get pics and post.
I have a few sets all from clean CA trucks no rust no damage.
I don't keep anything not clean, not worth it.:D
Well I'll take them. Mine wollered out and I just don't want the same crap. Consider me in for both sides. PM me your addy and I'll get a MO out. :waytogo:
Thanks man but it looks like this is gonna work with iceman.
OK so I went out and checked my stash since the sun decided to peak out and give me a little bit of light.
I have a set that I had taken out a while ago still looking for that one, the rest that I took out last week and the frame I still have sitting all have the driver side bad and the pass side good.
Now they can be switched around, but they have a longer lip on the front so you can tell.
I need to look tomorrow again and see if I can find the other set unless you can work with 2 or one pass side then I can ship tomorrow morning.
The set I had set aside because they were impeccable, and I guess I hid them very well.:whistle:
Here is a pic of the set I have now, the driver side inside hole is slightly damaged because the guy torched the bolt of the spring and hit the hanger a bit.
the second set the holes are fine but as you see the body mount area has been massaged a bit.:doah:
Let me know what you want to do and in the mean time I will look for the other set.
I'm just after the very lower bracket that the spring itself bolts to. So which ever set has good holes there.
OK then, if that is the case I should have a couple of good ones from each side, I will take the rivets off and just get you the bottom ones, maybe even all the good ones, you can have some for spares.:thumb:
I will get it doen tomorrow and show you what I got and maybe I can make it to ship tomorrow.:waytogo:
