Front Spring Hangers
JEBSR
Clarksville, TN
A WHILE BACK I SAW A POST THAT I CANNOT SEEM TO FIND AGAIN SO IF ANYONE HAS THIS INFO PLEASE SHARE. I WANT TO GET RID OF MY EXTENDED SHACKLES AND RUN A BRACKET THAT WILL LOWER THE SPRING MOUNT POSITION IN FRONT TO ACHIEVE ABOUT 3-4". MY SPRINGS ARE FAIRLY NEW 4" AND DON'T WANT THE EXTA STIFFNESS OF 8"'S. WHERE DO I GET THESE????????? :dunno:
dropping your front mounts will only give you 1.5 or 2" of lift. However much you drop one side of the spring, cut that in half and thats how much lift you gain. No one sells a kit for drop front brackets, any you have seen were custom made. If you do it yourself, make it supported. Gusset to the frame and triangulate! Don't want to read how you crushed a family van when your leaf springs disconnected from your frame.
OH AND PLEASE STOP SCREAMING
this is to make the 88-up leaf sprung. but you can use this as a gide to make what you want along the same idea.
