I have a 78 Blazer. Has anyone installed the replacement front spring hangers, from Hogback Fab?
I have a set of front spring hangers from Off Road Design (ORD).
Offroad Design makes them for 67-72, and 81-87, but not for 73-80.
OOOPS! Your correct...they are DIY4X. I have half ORD stuff on my truck, and half DIY4X stuff. I sometimes forget which is which.Those look like DIY4X brackets.
My truck is a 1991 V series truck, but still technically a 81 to 87 truck.Offroad Design makes them for 67-72, and 81-87, but not for 73-80.
Is there a link these hangars?
hogbackfab.com
That would seem acceptable. And considering that the listing starts out with the K truck applications, it should fit them, I would "assume ".I think they were drilling holes for conversion from 2by
I was confused when looked up the hogback parts and looked at the fush upgradesThat would seem acceptable. And considering that the listing starts out with the K truck applications, it should fit them, I would "assume ".
@500$k5 has more to the story, and hopefully has some solution in progress by now.
I need a set for my Jimmy, which is on a '79 frame. I bought ORD springs, so the B52 brackets from DIY4X won't work unless I change bushings.
Those factory front spring hangers are a weak point on square bodies. I replaced mine because the rivets holding the two pieces together where all loose.We have one now, that fits too! We had this prototype set floating around here for a couple of years:
but when we tried to fit it up a couple months back, we got this:
And this:
So we started over and now we have one that will not only bolt onto the frame without major swiss cheese work, but also fits with a stock bumper brace.
https://www.offroaddesign.com/repla...ing-hangers-for-73-80-gm-4wd-trucks-pair.html
First welded steel article of the '70's C truck 2-4wd conversion brackets were bolted to a 76 C-30 crew this morning and passed the test so they'll be available soon too. In this case, "bolt to" means the existing holes lined up. C-trucks basically just have the body mount holes to work with so we added a few to that one for sure.
