front spring rear eye bushing
Steve GMC
middletown,Connecticut
ok so i got a set of diy shackles so i can get the 9/16 bolts for the rear of the front spring... my question is does anybody make a 9/16 bushing for the spring eye on the front spring??? ive searched and couldnt find anything...
thanks
we are both wondering... i have been searching forever
more info, we are both using stock length lift springs, and the fush kit will be going in the stock location
we have 86 trucks currently using 7/16" bolts in spring and upper shackle
http://www.offroaddesign.com/catalog/hdshackles.htm
[FONT=Arial, Helvetica, sans-serif]Part #: GU37013 - $29.00 (1 1/8" main eye bushing fits Superlift and Skyjacker springs) Buy now
i have skyjacker springs
i had found this the other day, but overlooked it as it didnt have a size, i will call them tomorrow and ask
thank you
the other issue we were wondering was if there was a bushing somwhere that allowed a 9/16 bolt and also was not as wide so that you could use the diy fush kit without adding washers
[/FONT]
