Front suspension lift
newbie79
St Louis, MO
Maybe a stupid question but can you put shackles on the front. I need another two inches in the front and currently have 6 inch springs. Also I can't find any shocks for 8 inch suspension lift. Am I missing something and where can I find them
Thanks in advance
No. There are heavy duty shackles that ord sells but they won't net noticeable lift.
Get an easy inch.
Thanks in advance
I'm guessing you don't want to trim?
you need to move the axles on that thing.. get an ez inch/zero rate and lift it an inch, but more importantly, move the axle forward 1.5"s..
that back axle could go back 3"s easy to fit that wheelwell, but that one wont be as simple as an ez-inch/zero rate..
and no, you can't put shackles in the front, your axle would flop forward/back..
Ryoken no issue with cutting on the blazer, thanks for the help. I already had to cut them to fit the new bumper. I am gonna go with the zero rate up front and I will figure out the back later
