front suspension mystery part
sandypants
spangdahlem AFB Germany
ok i cant seem to find the name of this part. on the front leave springs suspension...on my 89 blazer the part on the frame that has connects to the leaf sprind via shackle. that part on the frame. what is the name and where the heck can i find a whole new bushing/bolts. thanx :bow: jeff
It's most likely a "spring hanger", you'd just need to define front or rear. If rear try looking at either ORD's or Diy4x's site for replacement parts. They both offer bushing kits as well as new & improved brackets (if needed).
The first link, are those rubber or poly?
FYI Sandypants, factory bushings are still available, but very costly unfortunately.
yea thats what im affraid of but im on a deadline, im getting stationed in germany and before i go i need to finish my blazer so i can drive it back home to missouri from fl. any ideas where i can get those cups for body mounts?
ord did seem to have it. they only offered it with shackles but were willing to work with me on splitting it up so i can order just the bushings and greasable bolts. so very happy with them. probably going to order more stuff from them now:D thanx again for the help
Sounds like you're talking about the frame shackle bushings. You can get them from energy suspension. I have a brand new box sitting on my shelf at home, i can get you the part number later if you need it, also the sleeves are different than earlier years because GM changed the bolt size starting in 1988 or 1989
