Front sway bar question
hawkins
Registered Member
kendallville Indiana
When swapping in my d44 from my 71 truck into my 88k5 I will not have the sway bar on the front. Is this still safe on the street? Im going to assume yes because none of the other 3 or 4 trucks Ive had had a sway bar in the front. I just want to be sure first.
Yull be fine. Might just lean a little if you swing a sharp turn when you park. Other than that dont turn like ur an f1 driver and you'll be fine.
