front wheel studs
kamm
Registered Member
norristown Pennsylvania
I am wondering if anyone can give me an idea of what is invloved to seperate the hub from the rotor. Any insight will be much appreciated. Thanks to all!
The proper way is to support the hub/rotor assembly and press them out, if you don't have a press or a local machine shop to do this for you then you can carefully do it at home with a brass drift to remove them and then reverse that procedure to install or use a stack of washers and LOTS of lube to draw them back in using a lugnut.
