To say the installation instructions are lacking would be quite the understatement. A few key notes would help a ton. Also, Ive searched here and the rest of the internet and cant find a single install writeup for a Blazer which is quite surprising. Guess Ill have to make my own.
- There are 3 different length bolts supplied but there is no explanation where each is supposed to go. I found one mention of the super long bolts being used for the front mounts. Not 100% sure about that though.
- The lift pucks dont fit over the studs that come down from the inside of the forward cargo area. This leads me to believe that the studs need to be removed but there is no mention of this. There is a note about needing to pull up the carpet but thats it. Does the stud have a hex head on top so it can be removed with a wrench? Or is it welded in place and needs to be drilled/cut out? Which length bolt is used for the 4 mounts in the cargo area?
- Are the lift pucks supposed to go against the body? Or in between the frame and rubber bushing? Im guessing against the body because some of the bushings have sleeved washers that wouldnt sit pretty with the puck below.
- There is mention of carriage bolts and captured nuts. Where are they? What needs to be done with them?
