Whats up guys, I have been dealing with a very troublesome issue with my o2 sensor on my 87 k5 tbi
. After I had owned the truck for about year, I decided to put a nice set of headers on it and run a good exhaust setup. Well, as all of us know, the stock single wire o2 sensors do not like to be ran with headers since they cannot maintain the proper heat. The truck would run fine in the city, but whenever I would hit overdrive on the highway and cruise for a bit, the check engine would turn on. Well, after reading quite a bit on here, I decided to convert my single wire o2 sensor to a three wire heated sensor. it is run off of an ignition accessory and is receiving 12 volts when the truck is running(has been tested with voltmeter) Well after going on a short cruise down the highway, there was that annoying orange light on shining back in my face again...
When the key is turned forward, the sensor will get somewhat warm to the touch after a few minutes, but never really hot. The sensor is also a brand new ac delco that I had purchased off of amazon. Could this sensor just possibly be a dud..?
Thanks in advance for the replies!
Shane
When the key is turned forward, the sensor will get somewhat warm to the touch after a few minutes, but never really hot. The sensor is also a brand new ac delco that I had purchased off of amazon. Could this sensor just possibly be a dud..? Thanks in advance for the replies!
Shane
I would have never guessed that! I love how simple pretty much everything is with these older squarebodies..
Well anyways, I tried the trick on my truck, but it just kept flashing the 12 code. The starter had gone out on it and It has been sitting for about a week with the battery unhooked, so it must have cleared itself. But the new starter arrived from summit earlier today, so that's tonight's project.
As soon as I get it out of the garage again and get the code to pop up, I'll post it on here..
Do any of you guys know of a solution to eliminating this issue?
) Im sort of afraid because alot of my egr stuff got torn off and thrown around while putting my exhaust on I believe.
