AZ FS: Custom dual rear bumper swing outs (Expedition style)
pma4x4
AKA Yankeeroad
Apache Junction, Arizona
Changing things up a bit. We're not going to be using the Mule for cross country much anymore so the swing outs are up for grabs.
Custom dual swing outs. These came of my barn door 91 Suburban. I used to sell custom bumper and stuff and have changed gears and no longer need these on my truck. they served us well with a few trips across the US back country. Together they weigh 98lbs. You can open the pass side to gain access with the single barn door if need be. Will clear tailgate design as well. Comes in powder coat wrinkle black.
Designed to hold
Spare tire with 6x5.5 pattern
High lift
axe
pick axe
short shovel
10-20lb CO2 tank (depending in diameter of tank)
5lb Propane tank (included)
(2) genuine Nato Jerry cans (harbor freight ones should work)
pop lock pins to hold the swing outs open.
Spot to mount your license plate and light it up.
greasable common bearings for the spindle
Comes with brand new machined spindles and sleeves. NOT TRAILER SPINDLES.
Also comes with larg lock to secure Hi-Lift
Swing outs only NO BUMPER
$600 for the set. Meeting somewhere in Arizona is possible IF you pay in full via Payal, MO or CC.
Locate in Apache Junction, AZ
Build thread of it can be found here.
I'm interested if you still have them. If not would be willing to pay you to build identical for my 1989 v1500
