FS: D60/14blt axles, 39.5 TSL's, beadlocks, ORD x-over steer, hydro, springs
chevyin
Pismo Bch CA
Hey guys, down to my last set of 1-tons. This was my best set that I was keeping for my rig. But plans have changed, and tired of having this stuff but no time to build the truck. So here goes.
D60 front, 14blt rear. Out of mid-80's (iirc) Chevy 1-ton non-dually. Hadn't decided on lockers yet, so open diffs, 456 gears. Axles were rebuilt with new seals, bearings and kingpins per the rebuild kit purchased from shakerbuilt.com and professionally installed locally. Gears were like new and left alone. Spring perches were moved, and have heady duty perches. Rear axle already has disc brake conversion added. Brake lines not included, but aftermarket mounts, new rotors, and new calipers are included and mounted. Axles have both been sandblasted and repainted with POR-15, but touch-up will be necessarry in a couple places.
Front axle has an ORD cross over steering kit installed (shown in pics) minus the pitman arm. Its still attached to the steering gear box that's yet to be located in my storage units (recently moved). But the ORD x-over does have the drag link with ends, and steering arm.
Front axle also includes custom mount for hydro-assist steering ram in the form of a plate the diff cover mounts to. The ram itself has started to have the paint come off and show signs of rusting externally, but has never been used and should function 100%. Its a 1.75" ram. It was part of a West Texas Offroad hydro assist kit purchased for the truck, the (again) steering box and hoses for which have yet to be located as well. Thread will be modified upon my finding additional parts I find, but as of now this ad and these prices as for the items shown and listed as being included.
Wheels and tires. Tires are 39.5" TSL's. Purchased last year, zero miles. Absolutely brand new tread. Wheels are USA6x6 double beadlocks, 16.5", extra wide (dont recall if they are 10 or 12" wide, but they fit the tires perfectly imo). The rockrings are custom, drawn by me (saw tooth design) and added by USA6x6. Double beadlock design utilizing PVC inserts, modified to better accept the use of balancing beads. 'Dynabead' balancing beads installed. Wheels have a thin coat of black on them, but have never had a serious paint job. They will need a quick coat of black to look like brand new. Again, zero miles on wheels also.
Also shown and for sale are the set of 8" SkyJacker lift springs. Need a fresh coat of paint, but otherwise brand new. Zero miles.
And shown on my old truck for reference:
Prices:
axles, including hardware mentioned as included and shown in the pics, but not including springs... $1500.
Wheels and tires (will not seperate)... $1750.
Springs... $650.
Items are located at a relative's home approx 30 minutes away. So I will a little notice on meeting to look at the items. Sorry, pick up only. Location is eastern Iowa. Thanks for looking.
I forgot to mention, the D60 has MileMarker stainless steel hubs, brand new. Also, I found the hydro-assist steering box today, so the axles will also include the freshly rebuilt and converted 2WD steering box by WestTexasOffroad, and the pitman arm for the ORD x-over steering (making that the complete, iirc, $440 xover steering kit).
Also forgot to mention the springs come with ORD greasable shackles, as shown in the pics.
This is a very nice turn-key setup for somebody. Basically all new parts, setup the 'right' way. Who wants to make their truck a monster? :D
New prices:
wheels and tires: $1400
axles plus mentioned hardware (hydro, xover, etc): $1250
springs: $400
These are basically give away prices because I need the money for a house. Someone take advantage of my situation and buy these things for a fraction pof what I have in them.
Thanks.
Ive already had someone ask about the xover steering seperate. Id prefer to sell the entire package, as its a great turn-key setup for someone. Im sure Id make more money selling it piece by piece, but time is of the essence for me right now so Im trying to give someone a smoking deal to take it all. But Im getting no interest in it all so far, so I may be parting it out soon.
I also have a shakerbuilt xover steering kit which will be for sale once I figure out where I put the steering arm for it. If you dont need a steering arm, we could probably work out a deal on it.
Thanks.
edit: oops you said you dont need pitman arm, not steering arm. My search for the arm will continue tomorrow.
