FS JD314 with P/A plow chains/weights Pa
norville
A stones throw from Pargon Mountaintop Pa
Folks, I regretfully selling my 314, It has been converted to a dual circuit to run dirt/snow plow. It has non-JD cast weights and a set of chains with it. It just won't work for me. My drive is just to steep and I have a 300 for grass duty. The plow is in great shape and works well. The tractor smokes a bit on start up but pulls strong. It started every time in the summer, no issues. I did have to give it a shot of ether to get it started this winter. the left right on the H2 unit sometime stick and you have to pull both levers. I have all the parts to convert it back to a H1 if desired. There is no mower deck. The tires are old but good, one looses air in the cold. The seat is not original but I have a JD cover here you can have. Although the seat looks odd it it very comfy. It needs a grill and light cover, no tail lights?. There is no rot on it, it was however painted at some time and not the best job. Since the winter came the choke pull is a bit sticky. I used this tractor all summer to pull the cart and yard duty It runs and drives better than my 300
I'm asking $850 for the whole setup. I would consider selling just the plow for $500, the tractor for $400, weights and chains $100. But the tractor or the plow has to go before the weights and chains go. If you have any questions let me know. Locally I can help with delivery for some beer.
I'm in Pa 18707
thanks,
