FS: Yukon Carrier/Bearing Pinion Puller - never used and extras
dbreid
San Mateo CA
All,
I couple years ago, I bought one of the Fancy Yukon Bearing pullers from Randy's. At the time, I was gearing up to... well.. regear a few axles, but I wound up going a different direction, and never used that tool. I paid a bunch of money for it (They retail for over 550 from Randy, and about 500 from completeoffroad), and I also bought the shim drivers (look like forks) in two sizes, and I even have some gear paint in little plastic "pop" bubbles for doing r&p's.
The tool itself is brand new, with the instructions. The main "bolt" still has all of the packing copper grease on it, and is still wrapped in the paper.
I will post some pictures of mine later tonight, but I figured I'd post this up and see if anyone was interested.
Here's some info:
http://www.ringpinion.com/ProductDet...px?ProdID=5277
In looking, there appears to be a couple different Part numbers now P20 vs. P22. I am not sure which one I have, as it doesn't appear to be marked, and I don't remember there being two models when I bought mine.
It is a VERY hefty tool, and is quite nicely made. It is also pretty heavy, so I'll likely ship it FedEx ground.
Given that it is unused, and has extra parts (carrier shim drivers, which cost 25.00 each from Randy's as well... See: http://www.ringpinion.com/ProductDet...px?ProdID=5292 as an example.) I'd like to get 400 dollars shipped in the lower 48 for it.
No tax or anything, so that is saving you about 200 bucks off the Randy's price. Maybe a little less if you count a lower price on the tool if you can find one, but either way, a dang good deal.
Also, I am in the Bay Area of CA if someone wants to come pick this up.
Here are some pictures:
If you are interested, email me at Dan AT Reid DOT Org
-Dan
