FUEL CELL plumbing questions
juanblzer
Chandler, Arizona
I will be ordering a 32 gal. Jazz steel fuel cell. How does one plumb a fuel cell? I have an 85 so no pump in the tank. Any and all help is appreciated.
juan
/forums/images/graemlins/k5.gif
umm, if it was me, i would ditch the mechanical pump for an expensive electric one. kind of sucks that way in some aspects, but does work better. summit sells a kit for 270.00 dollars. it includes the pump, filter, line, fittings, and regulator. kind of spendy, but not a bad way to go. part number SUM-PUMPKIT7A
so it would go like this:
fuel cell---filter-pump-------regulator---secondairy clear filter-carb.
grant
oh yeah, how much you paying for the cell?
and where from? foam filled? part number? /forums/images/graemlins/laugh.gif
grant
It's really pretty simple. Keep your stock mechanical pump. It's one of the best engineered things on your truck already and really tough to kill. You should have 4 bungs on your cell. 2 on top and 2 on bottom. Here's what I did on my '79. I ran one of the bottoms to my metal feed fuel line with 3/8 or 1/2" rubber hose (can't remember what size). I capped off the other bottom bung in the sump. On top, there should be 2 more bungs. One has a tipover vent valve that shuts off if the cell is upside down. You want to run a length of rubber hose off of this bung and coil it up with a filter on one end. That way it can still breathe, but no fuel smell can come out of the end. The other straight through bung should be routed via rubber hose to the return hard line in your truck.
As for fittings, you can use the expensive ass aluminum anodized ones in summit magazine. Or you can do what I did and use JIC hydraulic fittings. Same thread pitch and mounting angle. Only these are dipped steel and about 1/4 the price. I took my whole cell into one of those awesome autoparts stores where the guys actually know something and also work with tractor hydraulics. They fixed me right up with fittings and hose. Hope this helps. I took my cell out last week since i parted out my rig. I have it sitting in the garage with the fittings still on it. Will take a pic tonight before I ship it off to its new owner.
HTH, Bryan
Edit that...guess you dont' have a bung for a return line...in that case, you'll need to cap your return line off at the carb and just run a supply and a vent. The vent one will have a check ball in it that you can see... /forums/images/graemlins/grin.gif
