So, I converted to my carbed engine to TPI and all was well for a while, but then, wham...started sucking crap into the fule filter. Changed the filter, and the engine was better , but still not getting enough fuel. I have the tank off and will replace it wiht a fuel injection one with internal baffles (and not 30 years of dirt in the bottom), but here is my question. Is there any reason to replace the sending unit? I am still using the stock one and running an external fuel pump.
I don't know what the GM pumps are rated for, 190 might be more than enough for all I know. I'd probably research GM specs a bit more to make sure you aren't paying for something you don't need. It would likely be louder, and more prone to failure (if higher than GM specs) because they are forcing more work out of the same size package.
