fuel delivery and throttle question
buffblazer
Fort Collins Colorado
well i posted not to long ago about throttle linkage, and got some help on what kind of bracket to get.
now i wanting a new cable, i have heard about custom stainless steel lines that dont bind so what would yall recomend for a new cable?
and for the fuel, im wanting to run a line from the fuel pump to the carb with a pressure gauge and in line filter, who makes a complete pre bent after market set up
the truck is an 86 k5, 350 and the carb is an edlebrock 1406
Ive read some bits on the critical need for proper trans kick down or TVS?? cable adjustment with non stock carbs and linkages. Might wanna check it out if you havent already.
oops should have also said im running a sm465, but thanks for bringing it up in case someone else wants to do the same thing and has questions.
