Flamin' Fast
Registered Member
i have a 1987 jimmy that has a pretty healthy 383 in it. the previos owner destroyed 90% of the wiring throughout the truck so right now it has the old school holley projection system on it. im not a big fan of the projection and it cant stay tuned to save its life. would it be worth it to through a carb on there? i still have the factory throttle body and computer, just no wires to connect it. would the stock TBI flow enough for this engine? i just want to truck to finally run right.
....anyway if that is not an option for you id go with the option a couple posts up with the guy from 3rdgen.org.....or get the newer projection and find some one to tune it correctly....either way good luck lemme know how it goes...
