stallion85
Ok here's the deal. This is a recurring problem so I will tell you what I have done and what is going on. So far I have replace my fuel pump, fuel filter and my carb was rebuilt about 3 months ago (Q-Jet).
When my truck sits for a few days it will not start, does not get fuel to the carb. It will crank over and not even think about starting. I disconnected the line directly to the carb and no fuel squirts out while cranking. I took off the fuel filter and ran some air through it and it was not clogged. I then blew some compressed air through the fuel lines back into the tank and through the line to the carb. Both gave me the impression they were not clogged.
Now here is the kicker, when I dump fuel into the carb to get it to fire she will start after a few doses, then run great and start right back up again??? WTF is going on??
Any help will be greatly appreciated
I was hoping not though. As for how long I crank on it, I would say almost till the battery starts to die, so a long time. Never been inside a tank before....
