fuel filter base
bear76
here
Dose anyone have the GM part # for the diesel fuel filter base for a 6.2? The rectangle standyne unit.
Thanks.
PM me tomorrow and I can probably get you one if someone doesn't post it tonight. :)
I'd ditch it...
I'd put an earlier style spin on filter base on it,or buy a WIX aftermarket one that takes the #33123 fillter with the drain valve on it(about 25 bucks + the filter)....those square ones crack or leak too often IMO..plus they dont hold as much crud before clogging..:crazy:
From what I see, 14043724 "PLATE, F/Fltr Mtg" is the filter base (looks sort of triangular in the drawing) and 15593999 is the "FILTER, Fuel".
I'm not familiar with the diesels, the hoses shown going into it are all "fuel-oil Evap" labeled.
