The most common cause of gas gauge trouble is a poor ground, especially at the tank sender unit. It is important that all wiring connections are clean and tight, and free of dirt and corrosion. A poor ground or loose connection to a gas gauge is just as likely to cause problems as loose or dirty battery cables assuredly will with your starting system.
For example, if the gas gauge needle remains on empty when the ignition key is turned to the "on" position and you are sure the gas tank is partially full, battery current may not be reaching the gauge. To check further, connect a jumper wire between the ignition switch and the dash gauge. If the gauge now works, replace the defective wiring between the gauge and the ignition switch.
If the gauge needle remains stuck in one place, try turning the ignition switch off and on several times in succession. This will allow you to determine if it is the dash gauge or the tank sending unit that is defective. If turning the ignition switch off and on (a half-dozen times is a good test) does not seem to help, and you've verified that the dash gauge is receiving power, try the following troubleshooting steps:
A functioning sending unit will have a high resistance when the tank is full and a low resistance when the tank is empty. If the gauge reads higher than it should, make sure the wire attached to the electrical terminal on the tank sending unit is making a good ground connection. If necessary, clean the connection and reinstall the wire to the terminal, then check the gauge operation. If that didn't fix the problem, use a jumper wire to ground the electrical terminal on the tank sending unit to the tank unit housing (leave the wire to the gauge connected to the tank unit). Turn the ignition switch on. If the gauge reads empty or below empty, the sending unit is defective.
If the gauge still reads high, try grounding the tank unit electrical terminal to a clean portion of the frame. If this brings the gauge to empty or below, the tank unit is OK, but there is a bad ground between the gas tank and the body or chassis (or less likely, between the tank unit and the gas tank). Either way, find and correct the bad connection or merely run a permanent jumper wire from the frame to one of the screws holding the tank sending unit to the tank.
If the gauge still reads incorrectly, the wire from the tank unit to the gauge may be faulty. Check by using a jumper wire to ground the tank unit terminal on the gauge (the one not connected to the ignition). If the gauge now reads empty or below, the problem is in the wire leading to the tank (or its connection to the gauge). If grounding the tank terminal still doesn't cause the gauge reading to drop to empty or below, the gauge is faulty.
When the gauge reads lower than it should, check at the gauge by disconnecting the wiring from the tank unit. Turn the ignition on and if the needle reads full or above, the gauge unit is probably good and the tank unit or the wiring leading to it are probably the problem. Reconnect the tank unit wire to the gauge before proceeding.
The next trouble-shooting task begins by disconnecting the wire to the tank sending unit. If the gauge still reads full, there is likely a short to ground somewhere between the sending unit and the gauge. Look for worn insulation allowing the wire to contact the body or frame. If the gauge reads full or above with the wire disconnected, the problem is in the tank unit rather than the wiring. It could be an electrical fault, or the float may be stuck or may have sunk because of a hole caused by corrosion. Remove the tank sending unit and check it. If the float is bad, you'll likely hear gas sloshing around in it or see gas dripping out. If the float is OK and the float arm seems to be swinging freely through its full range, replace the tank unit.
Ground the gas tank terminal post of the tank sending unit using a jumper wire. If the dash gauge now reeds empty, the gas tank unit is defective. If the dash gauge needle fails t move, the dash gauge is defective.
If the gas gauge works, but reads lower than it should, check for defective wiring between the gas gauge and the tank sending unit. Also check for a poor ground at dash gauge and the sending unit by using a jumper wire. If the dash gauge reads empty when the tank is actually half full or greater, the wiring between the dash gauge and the tank sending unit is defective. Disconnect the wire at the gas tank sending unit terminal. If the gas gauge reads still reads empty, the dash gauge unit is defective.
