vandelay industries
1) Would anyone happen to know the sizes of the rubber fuel hoses going to the fuel pump from the metal hardlines? Both supply and return. This is for small block.
2) Do these hoses usually deteriorate and eventually need replacement? i've only seen one instance of one (supply line) leak.
The only reason i'm replacing mine is because i've swapped in a 4.3 v-6---which means the fuel pump is farther back and the v-8 lines won't reach it.
3) Can you recommend a good brand?
