It does starve for fuel when the tank gets low.
Peoples heads should roll.
That sucks that those trays are that much of a problem. When I got my tank I wondered what exactly it was supposed to do, at least compared to the stock setup.
I guess most people don't use trucks as trucks, therefore they don't see any difference.
I'm still not following the logic. You have gas in the tray, but it is being consumed. So if the truck is on it's side for long enough, it will run the tray dry. How does more get in? Then with no angle - let's say the tray is 3" tall - how can you ever drain the last 3" of fuel from the tank?
