I would have to agree with Ken. The Holley system is good, I'm sure but the GM TBI system is far superior. Typical scenerio, you are in Moab and have a computer problem, Go to a local junkyard and buy one for $15. You can buy most sensors at local parts stores. You can probably even buy a new throttle body. The good thing about the GM system is If you do have computer failure, you still can drive it home. It may be less than optimal performance, but you will make it home (from what I have heard). The installation is pretty simple and much cheaper than Holley. If you do go this route and purchase the parts at a junkyard get a few things:
Write down the VIN number from the vehicle for future reference in the service manuals.
Wiring harness complete with sensors and connectors. Make sure to either unbolt it at the bulkhead or cut it. Get the ALDL connector (diagnostic port), wiring to Fuel pump.
Sensors: Knock Sensor, TPS, IAC, MAP, VSS, Temp switch, Oil pressure switch, ESC, O2
Distrbutor, cap and rotor, Module, Coil and electrical connections
Intake manifold, Throttle Body
Fuel Lines, Fuel pump, Fuel filter
Check engine light from dash if possible
Exhaust Manifold with O2 sensor
This is a pretty complete list of parts you will need. It sounds overwhelming but it is a great system and needs this to perform well. Be sure to avoid cutting the harness or sensors off. You want a well sealed and properly spliced wiring harness. Having many splices in the wiring harness will wreak havok on troubleshooting. Usually most diagnostics will only tell you about sensors and their functions, not wiring problems. Take your time. I would be glad to help you if you have questions. I will probably do a writeup on this soon. Go to your local Library and check out a Mitchell manual or Factory service manuals for the year of vehicle you pulled the parts from. The years are '87 and newer V8 powered Trucks, K5s, Vans, Caprices, etc. I got lucky and found a wrecked K5 and I bought the fuel tank and lines from it. I had already purchased the rest of my system from an '87 Chevy Van. Get all the parts listed or if you would rather, take the numbers off them then buy new ones. You can save alot by getting the used sensors as long as they are in good working order. My entire system cost $150 then I bought the tank and fuel pump/lines for $100. It took me about a week of looking through a Mitchell manual and sorting my wiring harness. But it is worth it. Good luck.
http://www.mudzer.coloradok5.com
Mudzer 1978/91 K5
