Went to replace my gas tank.. when I dropped the tank I found this below
Not sure if this happened while I was dropping the tank.. or if it has always been like this. But it needed to be replaced. Anyway… I cut the bad piece of line off and replaced with fuel injected rubber hose. In the hose I put a piece of brake line and doubled clap both ends. Then I wrapped it in heat shield.
Got it all buttoned up and when I crank it up it was leaking. So I need to replace this line, but the original has some factory crimp. What is the best solution? I don’t have any crimping tools or anything.
