Fuel line clog
wazzabie
Washington State
I have a k5. The main fuel line is clogged. It is the section that is in the front as the line is a two piece. I know it is clogged because I disconnected the fuel hose and vacume tested it. The line with both ends open held 15lbs... 10lbs after 12 hrs.
I tried commpress air. No go. Hoe else can I unclog the line?
Take that piece of line out and put it on the ground and tap on it to try to loosen the clog, or use what electricians call a steel fish tape and shove it thru there.
Tarey
update: the line was so clogged because it was full of rust. I took some fish line to clean it out and rammed a hole in it.
