stunter2boy79
Registered Member
need in some help. i brough an 80 k5 blazer and love it. always wanted one. sorry for vering off but i have a fuel leak. i belive it is the return line. its the line all the way on top above the 3 lines together. i tried just tube cutting the line and replacing it w rubber fuel line, well that didnt work so well, then i notice i needed to flare the end. i used the standard brake flare and that didnt work. what kind of flare it this? how can i make this flare? does anyone have pics?
should i just buy new line or longer rubber line w the plastic jointer peice. just need a quick fix untill i tear her down next spring 2 replace it all.
thanks adam
thanks adam
