GorillaGlue
Registered Member
In my 89 k5 blazer, I installed a new sending unit, and the braided stainless lines were completely rotted at the fittings. Assuming that I secured everything the correct way and double flared my hard lines, could I just run rubber lines to the sending unit? The pressure should never exceed 15 psi and from what I’m aware, a good 350 tho stays around 13 psi. Would this be dangerous or at risk of leaking?
