Cubman
Registered Member
When I swapped a new gas tank into my K10, I decided to replace all the rubber fuel hoses at the same time. The 3/8" hose that goes from the hardline on the frame to the inlet of the fuel pump has to make a 180* and a 90*. It was fine when I put it in, but now the line kinks in one of the two places. I was able to 'wedge it' against the return line to get home, but I need a more permanent solution. I got some 5/16" fuel line and bent up a 180* elbow and a 90* elbow. Will this work ok? Are there any coatings on brake lines that will be hurt by gas? Will the line be too restrictive for fuel to flow properly?
