fuel line rated quick conector for jerry can use
sweetk30
Back to play nice .
in the back of your brain
want to have a fuel hose with a quick conector on it that wont flow fuel if not pluged in to hose .
idea is a fuel pump mounted on the truck frame pulling from second tank to be my jerry can of sorts. if the end that wont flow fuel can stay bolted/sandwiched to the bed area and not move this would be a big help.
3/8 hose size is all i need it for .
anyone got anything ? :dunno:
well the air quick disconnects but hooked to a fuel rated hose.
I want to do the same thing but I haven't had time to try it yet.
Aeroquip makes what you want.....
http://aeroquip.cc/aeroquipquickdisconnectcouplings.aspx
I used them in the past to connect Thermo King reefer units to the cab A/C on big rigs...that way the driver could drop the trailer and pull out from under it...
I used them on the suction and liquid lines with refrigerant, so i had to have something that closed on both the male and female end of the quick connect... Aeroquip to the rescue !!!!:woot:
