cegusman
3/4 ton status
I am installing a fuel cell in my K5.
The fuel return line for my diesel is 5/16" Which would be a -5 fitting but they do not exist. The return port on the cell is a -8.
I plan on just running the rubber line hose clamped to the stock steel return line. Then to the correct 90 degree fitting, to a -8 to -6 reducer then to the cell. Would it be ok to just use 3/8" hose and clamp it tight to the steel line? It is only a 0.0625" difference in inner diameter.
