1st what causes the engine to stumble as you lower the idle? is it fuel pressure ? or volume? if i increase the pressure at a lower idle-could i possibly turn my idle down to almost barely there? poss 300? but have no stumble?
only 31s said:again i ask a question and people without facts try to answer it -then they disect it trying to figure it out-just looking for facts -thanks anyway
Your ECM is programed to keep the idle around 650-750 RPM depending on application. Forcing the idle below the programed RPM really screws things up. Tne ECM will try to increase idle speed by adding more air thru the IAC. Which wont work so then it trys adding fuel. It is constantly switching back and forth between rich and lean. Causing a surging idle, stumbling, ECT. The only proper way to lower idle speed is to reprogram the chip.
Now, if he would have bought me lunch, that woulda been something!
