bp71k5
3/4 ton status
It looks to me like the relay "A" terminal and the oil pressure switch are on the same circuit , and if either one of them is OPEN, then the fuel pump circuit is not complete.
Check it carefully again. If the relay is working correctly, the 12v hot from the battery will travel through the relay and straight to the fuel pump on the wire (in the diagram terminal "E") that's on the right and drops down and runs under the relay (in the diagram) straight to the pump, bypassing the oil switch. If the switch is also working and sees 4psi, 12v will travel across it as well before going straight to the pump.
The purpose of this scheme is to let the truck still start when the relay fails, but do it in a way that tells you somethings wrong. It also prevents the engine from dying from a relay failure which could be a safety issue if you were crossing over some train tracks.
