Fuel pressure spring...
TBI's love the higher pressure.. I run 13.5 on my BB....
Mr Injector has the springs and other parts you may need when getting injectors serviced.
http://www.mrinjector.us/
Stock motor and chip handles 13 to 14 nicely, making sure your throttle blades have a minimum air setting really helps idle when you have increased pressure. As the TBI wears the throttle blades close making it harder for fuel above throttle blades to mix with air.
15 PSI IIRC is max a stock pump will handle at WOT. It may do more at idle but drop when volume is maxed...
