Hey guys looking for a couple fuel pump access hatches to put in the bed of my kids truck. Can't remember who's done some nice looking ones. Please share them if you have pics or a link for a decent one. Thanks
Well...it's a cough cough '93 F350 crew cab long bed with a 460.This will give some ideas about the doors, are you doing a regular truck, crew cab or Sub/Blazer?
Fuel Pump Access hatch
mods, please delete if this is not ok. I added a fuel hatch to my blazer build during the rear links and frame install and thought I would throw up a video and blog post on it over on my website. Secure, functional, strong and big enough to provide adequate access. Should have done this years...ck5.com
Thank you. That did give me the idea to search marine access hatches.This will give some ideas about the doors, are you doing a regular truck, crew cab or Sub/Blazer?
Beat me to it!
DPI Marine DPF1317BLK DPF Flush Series Door
Nah... the still have the hatch cover. I can't bring myself to cut into the bedhey @TJ1978 you do this hatch mod yet ? If not now's the time brother
Both. A previous owner cut the bed already. It's gonna get both pumps/senders replaced. It's been sitting since '18/'19 and I don't know any history on the truck. I'm hoping I won't have to drop the tanks.Are you doing a hatch for the side tank or just the rear?
I was originally going to pull the bed but the bolts look a bit crusty and the floor was already cut by a previous owner.How hard is it really to lift the bed on one of those? When I think of a pickup bed, I want to be able to fill it with whatever, whenever.
Good start for sure. I used to have an '89 just like it with a '92 front clip and bed. Sat the same as this one. Mine had a cummins and a 5 speed and a Gear Vendor. All set up to work perfectly together. Could tow whatever you want up the mtns and no overheating or high egts. My kid loved it and that's why he wanted one. Scored this for $2500. Looks like the 460 should run with new fuel pumps I think.Pulling the tanks sucks, I did my rear one once and it needs it again already. My bed is coming off tho.
That truck has so much potential!
Yeah those look like a good way to go. I'd want to get an aluminum or steel version instead of a plastic one since it's a truck bed. The holes that were cut already are not big enough or in quite the right place so I'd have to get a piece of bed floor from a salvage yard if I went a different route. Going to get new senders and pumps then see how it goes.I real carefully made a nice rectangle, cut in the bed of mine, and built a small frame that I welded from underneath that I could build the same plate back down onto. I suppose a guy could weld some hinges on one side and use it like a hatch. Also, for what it’s worth the linked post above wasn’t the first person to suggest the marine hatch, just saying.
