vandelay industries
Notes:
i only need 4-5lbs. 6 lbs. max.
This is a 2WD longbed truck
1) Is there an electric fuel pump that pulls as well as it pushes or at least doesn't "mind" pulling, unlike most other electric pumps?
2) Are there low pressure belt-driven mechanical pumps available for small block chevy?
(4.3 blocks with fuel pump provisions are not easy to find.......)
3) How far is too far away when mounting an electric pump; i can get it about 30-32" inches away from the tank and below the level of the tank. Anything closer is difficult to the point that it may not be practical. i might be able to get at the fuel cluster thing but if not don't really want to take off the bed, make a door in the bed or drop the tank.
