I'd also check the wire that sends power back to the fuel pump for its ability to handle AMPS...using a test light or volt meter puts practically no load on the wire,and can show its getting 12 volts,but not with enough amps behind it to actually run the pump--or let it run a short time,then stop..
My friend replaces a lot of in tank pumps at his shop,and most GM ones now come with a new harness plug for the sending unit/pump power wire--they are notorious for corroding internally and causing intermittent problems...you are supposed to replace the oem plug and install the new one or the warranty will be voided..
He learned the hard way using a test light (especially the LED ones that draw practically no amps) is not a reliable test,nor is a volt meter..
One day I showed up at his shop after he had installed a new pump in a GM pickup,and it was towed back in a few hours later,with "no fuel pump" symptoms again...(and he had replaced the plug on the power wire)...he said "I saw my test light light up--but I left it connected and on,for a few minutes,and it started flickering,then it went out"..
I said "sounds like the wire is corroded all the way back to the fuse box and acting like a big resistor"...
I took an old sealed beam headlamp he had on a shelf and hooked a pair of jumper wires to it from the fuel pump power wire,and grounded the other terminal--turned on the ignition,the headlight glowed brightly for a good 20-30 seconds--then started flickering,dimming down,and we stood there and watched the filament in it just glow dull orange for a few seconds--then it went out!..I shut the key off,let it sit a minute,turned it back on,it did the same thing again...
My friend decided to trace that wire back to the fuse box,and just cut it off there and spliced in a new length of wire--the headlamp stayed on a good 5 minutes with no flickering or dimming,so we hooked the wire back up to the fuel pump with the new plug supplied with it,and the truck fired right up,and hasn't come back since..
He now uses that headlamp as a test lamp to check the fuel pump power wires..it has enough of a load to make the faulty wiring show up..we slit open the original wire and it was mostly gangrene dust for the first 2 feet back towards the fuse box from the tank!..had only a few strands left that weren't dissolved..the old pump still worked when he hooked it to a battery too,so it may not have been "junk" to begin with!..
