lak2004
Trying to finish up my tbi swap before the weather turns and I have a couple of questions regarding the fuel pump. I chose to run an external pump airtex e2000. Will I be ok running it about 5 ft from the tank on the lowest part of my frame or do I need to get it closer?
Also should I just connect inline with some rubber fuel hose?
Mine is not labeled inlet and outlet, would the side that has the wire terminals be outlet?
