Fuel pump
Bringing this one back, I too am about to install my cell, and was wondering if anyone had other suggestions on a good pump? 350TBI out of a 91 Blaze:confused:
I've been running a bosch pump for over a year now and it seems fine. It's one of the higher pressure versions though. I forget the model number though. I can check into it.
Edit: I'm using this one- Bosch 69100
what is the advantage of running more than stock?
There was no advantage in my case, it was just what the motor was requiring. I had better heads and exhaust that I guess breathes more than a stock TBI motor. If you're using a stock TBI motor with no mods, then you don't need anything extra.
ah, got cha
sooo...now i've got another question... do i need a fuel regulator in this set up?
There's a regulator built into the TBI so I don't think you need anything other than a good fuel injection rated filter after the pump and at least a sock or filter before the pump.
okay cool, i think i've got it all down. now for the installation...
