bowtieboy4life2000
I put a 87 engine from my blazer into my 77 sierra and i'am going to run a carb on it but the engine doesn't have a lobe for the manual pump on it. so what kind of electric pump can i run and not flood the carb
I used to run a Holley blue pump and HATED it, it was super noisy and changed pitch all the time like it was about to die. It never did, but I would recommend just about any pump but that one.
Q-jets are fairly sensitive to fuel pressure, I ran mine at 2.5-3 psi. Too much pressure and it will hold the needle valve open and the truck will run super rich. Even with my built 383 I never ran the bowl dry at 3 psi, don't get sucked into the "is the pump flowing enough" deal unless you're running LOTS of horsepower.
