Fuel pump?
jmjkorosco
Registered Member
riverside ca
I have an 88 with tbi once it gets hot engine stalls under heavy acceleration and sometimes has a hard time starting back up. I checked fuel pressure and it was running around 12 psi until engine got hot it then dropped to around 8 psi. Is it a bad fuel pump?
12 is good. 8 is on the low side. Could be a pump or maybe a small hole in the rubber hose on the fuel pump (in tank). When at 12 psi, is it running properly?
I had a similar situation once. Turned out to be a bad coolant temp sensor (on T-stat housing). It was sending a signal that the coolant was like -45F. The computer was dumping fuel in it to try to compensate. This would drop my fuel pressure a little. Eventually, it would die at idle when I stopped at red lights and stuff and sometimes wouldn't restart. This might be a less common problem though. Next time yours is doing it, unplug the temp sensor and see if it improves.
