Mcsjr454
Registered Member
Howdy all, I am redoing my 2nd 79 K5 Blazer, but this time as a rolling restomod, instead of a ground up custom. My final plans are for a daily driven 5.3, 4l60E, np241. 3.42:1 Gearing, on 31.10.50's. The fuel tank and lines need replacing as the ones in it now are rusted and leaking. So I figured since I will need the 87 model tank and sending unit I might as well replace those now, as I will need them later. The problem I have is, I have never ran an electric fuel pump to a carbed engine. (350 cid, stock, 170 hp, AC, PS) So with the knowledge of using a 1987 K5 Blazer tank and sending unit, what Regulator would I need to keep things working happy together? Would I run a bypass, or let the pump dead head? and would I keep the charcoal canister functioning or disconnect it? Any help would be appreciated, and constructive criticism is greatly appreciated.
My previous custom mentioned started as a daily driver along the same route, but quickly snowballed out of control after a few parts selections gone awry. When you start planning a project, don't set your mind on specific parts. Instead look at what is available, and what is being done. Often you'll find something better than you plans, that also has more potential.
