Just wondering ---lets say your 6.2 has some really rusty injector lines,and while your on a drive,one of them decided to start pissing diesel out....what will happen,besides the risk of flash fire and burning the truck to the ground!...............................................................................................Some guys I've asked who supposedly "know" diesels say it'll just start blowing white smoke,idle very rough,and most likely let air get in the injector pump,causing it to lose its prime,then stall and refuse to re-start until the line is repaired,and the system bled out again..................................
........................................................Another guy says it'll keep running as long as you dont shut it down,and the risk of fire is very possible,as the diesel is under 1000+ lbs. of pressure and will be finely atomized and very easily ignited,should it hit a hot exhaust manifold or pipe....................................................................................................I'm asking this because my truck fits this description,and I'm unable to install some good used injector lines now due to health issues,and I've been forced to use the truck as my daily driver (for short distances under 10 miles!) because all the other vehicles I own or can use are in a poor state of repair and have expired inspection stickers................................................................................................Should the worst happen and a line fails,how could you ghetto-fab a repair to it in order to limp home??...I know no rubber hose and clamps would work!...but could you flare the line after cutting the bad peice out and splice a section of brake tubing in ,or use copper tubing,as an emergency fix??.........I dont see J-B Weld being able to withstand that kind of psi for long if at all......so,are we basically screwed when a line fails??.............and have to be towed home??...............................................................................................If and when my back ever feels good enough,I plan to pull the intake and injector lines off and replace them,and at the same time,put on a J code intake I scored off a 1 ton ramp truck that had a 6.2 ...but it also needs the oil pan replaced (I have 2 good ones but cant lie under the truck long enough to install one),and both exhaust manifolds are flaking apart and look like they were in the ocean since 1900...might be easier to yank the engine right out and fix all at one on a stand,rather than bending over it for a week.........
...was just wondering if it were possible to limp home somehow by blocking off the failed line,or patch it some other way,in case I do get stranded!...
