fuel shut off valve
cybrfire
1 ton status
Iowa
You guys know of a manually activated shut off valve that can be bolted to a bulkhead or frame rail?
I have found a few but they have horrible specs as far as temperature ranges and so forth.
I've looked at everything Summit has to offer. Unfortunately nothing that bolts to a frame for mounting.
how about something like this?
The one I linked to is bulkhead mounted so all you would need is a tab with a hole in it.
It's a bulkhead pass through type of deal then. That could work. What Ryoken pictured is more what I had in mind.
Thanks guys.
whoever emailed the link. Thank you.
