Scott39
I have a 91 k5, it has a fuel cell in the back in the bed, it has a vent tube hooked up to the tank, and everything else is hooked up, except the hose going to the evap canister.
It cuts out alot when you use the throttle all the way to the floor, and vapor locks when it is real hot outside, and you can hear bubbling in the tank.
The cooler the temp is outside, the better it runs, doesn`t matter if I have a full tank, or a half tank, or almost empty tank.
Do I need to hook up the evap canister, and I do not know what kind of fuel pump that is mounted on the frame, I bought it this way?
