OK guys, looks like I'm going to change out my drivers side fuel tank on my 84 K2500. Can I use one from a 87 (with baffles for TBI) with my 84 sender?
Thanks!
Thanks!
Just keep the tank full
Well yeah.... the 87 TBI tank is dimensionally the same... as long as the 84 sender fits. (Reason 4 this thread)
Just find a baffled tank with the same measurements as yours. Should be ok
I just want the baffles to make the fuel gauge stop waving at me.
Thanks for the education! You probably saved me some coin, and that's a good thing.
My gauge used to flop around pretty good, then one day it decided it liked 1/4 tank and it stuck there.
My sender is grounded. When I disconnect the sender it goes beyond full. I have continuity from the press on sender wire connector down the harness.
Sometimes if I press down real hard on the sender connector it reads for a little while. So I also wondering if anyone repops the sender connector?
Yep, single round press on connector. With no threads on the sender I don't see how I can mod it.
Yes @ the tank. Cleaned the @$!@% out of both ends.Oh...you meant the tank end. I assumed the one further up the line. You might be able to pop the connector off and scuff up the post it sits on if it's corroded? Don't think I've ever dealt with that type connector at the tank.
I have not. I only folower the connector over the tank, through the frame rail. From there it appeared to splice into a body harness (tape). I did not follow it further forward.Have you tried running a jumper wire from that terminal to the connector further up, to figure out if it's the tank end or connector that is bad?
New sender isn't ridiculous to pay for anymore, but dealing with the top of the tank is a pain for sure!
Good info, how was the quality?last new spectra premium units I got for my self and a friend I found the best price shipped on ebay . I just got 2 tbi baffle long bed 20 gal tanks for under 90 each shipped a month or so ago .
same good quality spectra premium I have always gotten .Good info, how was the quality?
