grindkings
I'm building my engine. 350, .60over. Dish pistons, Holley 670cfm TBI with Projection manifold. Valve job and big cam. Possilbe fatter head casket for more compression. What type of fuel should i run. I'm
grindkings said:say what know? You said a fatter head gasket will lower compression. I thought it would up it.
Big Cam??? is it computer friendly? Need a custom chip to run a big cam with TBI
Fatter head gasket with dished pistons?? That will lower compression ratio a lot. Stock CR. is 8.2 to 1. Putting in a fatter head gasket will lower the CR even more so 85 octaine should be fine.
I hope you aren't building this engine for performance.
