Hello all,
i know this is probably a really dumb question, but please bear with me.
i'm putting back together a rear full floater dana 60. i am unsure if i should pack the bearings with grease or not. in a full floater doesn't the gear lube lubricate the wheel bearings? does this mean i don't need to pack them with grease?
i looked and the spicer axle service manual says the bearings "can be lubed either by axle grease or by rear-end gear lube". that doesn't answer my question.
If this was a front, i'd be packing them. i'm just not sure what to do with the rear.
Thanks in advance for help a gal out!
). So i don't think it has that special seal.
